Hi, you could make use of an AJAX Subform to dynamically load a subform based on some rules, or alternatively use custom JavaScript in a Custom HTML to perform the necessary behavior. When using JavaScript, you can use Javascript API#FormUtil to obtain the fields and its values.
Hi, can someone give me a hint on how to show only certain options according to another field data? By default all option is available whereas the annual leave option is only when Before start field > 5 can be selected by user.
