Like I said in my original post I'm calling the crud edit from datalist using hyperlink.
if I remove "Form (Edit)" from CRUD menu the hyperlink will not work.
I need a way to remove the link from UI only.
- Walter
If that's the case, then can try to use CSS or Javascript in the CRUD menu to hide the link manually.
Something like
span.row_action_inner a { display: none; } - Hamid Zahrir
yours removes both crud and datalist buttons.
to remove just the crud edit I used this
<style>
body .dataList
table tbody tr td.row_action.footable-visible.footable-last-column { display: none; }
table thead tr th.row_action.footable-visible.footable-last-column { display: none; }
</style>
In the CRUD Menu config, remove the form in "Form (Edit)"
i need to keep the edit crud but remove the link. I'm creating the edit link in the datalist and use visibility option to hide and show using conditions.
I wish there is a check box similar to delete button to remove or show the EDIT and ADD in userview.
can this be done using JS JQuery or CSS
Thanks!
