Hi, thank for the info. This issue is fix and will be available in next release. I will update u.
Thanks for your reply.
Yes i did (Shark).
The connection is ok but some tables (and indexes) may have been changed from V4 to v5... (the initializing sql script must be modified to take charge of this change).
PS : in v4 joget perfectly works with postgresql
- Aristo
Have you managed to fix this? Mind to share?
Did you follow all the steps in Running Joget Workflow with PostgreSQL? Especially step 7
7. Download Shark.conf, and copy it into joget-installation-directory/apache-tomcat-xxxx/webapps/jw/WEB-INF/classes/conf (you will need to create the conf directory first)
I'm running Joget Workflow V5 with postgresql 9.2 and it seems to work.
but when importing (uploading) app in a new postgresql database, this message appears.
this app was created from a mysql database.
-padungphong said
i reinstall joget and reeboot ubuntu server. it work!!
I don't undestand this solution from this issue.
i don't think it's a good remedy.
catalina out :
INFO 16 nov. 2015 16:50:48 org.joget.apps.workflow.security.WorkflowAuthenticationProvider - Authentication for user admin: true
INFO 16 nov. 2015 16:51:54 org.displaytag.export.ExportViewFactory - Initializing ExportViewFactory with type={csv,excel,xml,pdf}
INFO 16 nov. 2015 16:51:54 org.displaytag.properties.TableProperties - LocaleResolver initialized to org.joget.apps.app.web.LocalLocaleResolver.
ERROR 16 nov. 2015 16:52:27 org.hibernate.engine.jdbc.spi.SqlExceptionHelper - ERROR: current transaction is aborted, commands ignored until end of transaction block
ERROR 16 nov. 2015 16:52:27 org.joget.apps.app.dao.PluginDefaultPropertiesDaoImpl - org.hibernate.exception.GenericJDBCException: could not extract ResultSet
at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:54)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112)
at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.extract(ResultSetReturnImpl.java:91)
at org.hibernate.loader.Loader.getResultSet(Loader.java:2066)
at org.hibernate.loader.Loader.executeQueryStatement(Loader.java:1863)
at org.hibernate.loader.Loader.executeQueryStatement(Loader.java:1839)
at org.hibernate.loader.Loader.doQuery(Loader.java:910)
at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:355)
at org.hibernate.loader.Loader.doList(Loader.java:2554)
at org.hibernate.loader.Loader.doList(Loader.java:2540)
at org.hibernate.loader.Loader.listIgnoreQueryCache(Loader.java:2370)
at org.hibernate.loader.Loader.list(Loader.java:2365)
at org.hibernate.loader.hql.QueryLoader.list(QueryLoader.java:497)
at org.hibernate.hql.internal.ast.QueryTranslatorImpl.list(QueryTranslatorImpl.java:387)
at org.hibernate.engine.query.spi.HQLQueryPlan.performList(HQLQueryPlan.java:236)
at org.hibernate.internal.SessionImpl.list(SessionImpl.java:1300)
at org.hibernate.internal.QueryImpl.list(QueryImpl.java:103)
at org.joget.commons.spring.model.AbstractSpringDao.find(AbstractSpringDao.java:93)
at org.joget.apps.app.dao.AbstractAppVersionedObjectDao.find(AbstractAppVersionedObjectDao.java:82)
at org.joget.apps.app.dao.AbstractAppVersionedObjectDao.getList(AbstractAppVersionedObjectDao.java:63)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281)
at com.sun.proxy.$Proxy35.getList(Unknown Source)
at org.joget.apps.app.service.AuditTrailManagerImpl.executePlugin(AuditTrailManagerImpl.java:139)
at org.joget.apps.app.service.AuditTrailManagerImpl.addAuditTrail(AuditTrailManagerImpl.java:102)
at org.joget.apps.app.service.AppWorkflowHelper.addAuditTrail(AppWorkflowHelper.java:534)
at org.joget.workflow.util.WorkflowUtil.addAuditTrail(WorkflowUtil.java:337)
at org.joget.apps.app.service.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:27)
at com.sun.proxy.$Proxy28.count(Unknown Source)
at org.joget.apps.datalist.lib.FormRowDataListBinder.getDataTotalRowCount_aroundBody18(FormRowDataListBinder.java:145)
at org.joget.apps.datalist.lib.FormRowDataListBinder.getDataTotalRowCount_aroundBody19$advice(FormRowDataListBinder.java:94)
at org.joget.apps.datalist.lib.FormRowDataListBinder.getDataTotalRowCount(FormRowDataListBinder.java:1)
at org.joget.apps.datalist.model.DataList.getTotal(DataList.java:428)
at org.joget.plugin.enterprise.CrudMenu.getDecoratedMenu_aroundBody8(CrudMenu.java:75)
at org.joget.plugin.enterprise.CrudMenu.getDecoratedMenu_aroundBody9$advice(CrudMenu.java:94)
at org.joget.plugin.enterprise.CrudMenu.getDecoratedMenu(CrudMenu.java:1)
at org.joget.apps.userview.model.UserviewMenu.getMenu_aroundBody8(UserviewMenu.java:95)
at org.joget.apps.userview.model.UserviewMenu.getMenu_aroundBody9$advice(UserviewMenu.java:94)
at org.joget.apps.userview.model.UserviewMenu.getMenu(UserviewMenu.java:1)
at sun.reflect.GeneratedMethodAccessor128.invoke(Unknown Source)
at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:840)
at freemarker.ext.beans.BeanModel.invokeThroughDescriptor(BeanModel.java:276)
at freemarker.ext.beans.BeanModel.get(BeanModel.java:183)
at freemarker.core.Dot._getAsTemplateModel(Dot.java:76)
at freemarker.core.Expression.getAsTemplateModel(Expression.java:89)
at freemarker.core.Expression.getStringValue(Expression.java:93)
at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
at freemarker.core.Environment.visit(Environment.java:210)
at freemarker.core.MixedContent.accept(MixedContent.java:92)
at freemarker.core.IfBlock.accept(IfBlock.java:82)
at freemarker.core.ConditionalBlock.accept(ConditionalBlock.java:79)
at freemarker.core.IteratorBlock$Context.runLoop(IteratorBlock.java:179)
at freemarker.core.Environment.visit(Environment.java:417)
at freemarker.core.IteratorBlock.accept(IteratorBlock.java:102)
at freemarker.core.Environment.process(Environment.java:190)
at freemarker.template.Template.process(Template.java:237)
at org.joget.plugin.base.PluginManager.getPluginFreeMarkerTemplate(PluginManager.java:937)
at org.joget.apps.userview.service.UserviewUtil.getTemplate(UserviewUtil.java:78)
at org.joget.apps.userview.service.UserviewUtil.getTemplate(UserviewUtil.java:59)
at org.joget.apps.userview.model.UserviewV5Theme.getMenus_aroundBody26(UserviewV5Theme.java:152)
at org.joget.apps.userview.model.UserviewV5Theme.getMenus_aroundBody27$advice(UserviewV5Theme.java:94)
at org.joget.apps.userview.model.UserviewV5Theme.getMenus(UserviewV5Theme.java:1)
at org.joget.plugin.enterprise.JanuxV5Theme.getMenus_aroundBody26(JanuxV5Theme.java:153)
at org.joget.plugin.enterprise.JanuxV5Theme.getMenus_aroundBody27$advice(JanuxV5Theme.java:94)
at org.joget.plugin.enterprise.JanuxV5Theme.getMenus(JanuxV5Theme.java:1)
at org.joget.apps.userview.service.UserviewThemeProcesser.getMenus(UserviewThemeProcesser.java:493)
at org.joget.apps.userview.service.UserviewThemeProcesser.getHtml(UserviewThemeProcesser.java:183)
at javax.el.BeanELResolver.getValue(BeanELResolver.java:87)
at org.apache.jasper.el.JasperELResolver.getValue(JasperELResolver.java:104)
at org.apache.el.parser.AstValue.getValue(AstValue.java:183)
at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:185)
at org.apache.jasper.el.JspValueExpression.getValue(JspValueExpression.java:106)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspx_meth_c_005fset_005f0(v5view_jsp.java:182)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspx_meth_c_005fif_005f0(v5view_jsp.java:144)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspService(v5view_jsp.java:103)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:749)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:487)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:412)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:339)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:168)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:303)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1244)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1027)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:971)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:966)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:868)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:842)
at org.joget.commons.util.AnalyzerFilter.doFilter_aroundBody0(AnalyzerFilter.java:17)
at org.joget.commons.util.AnalyzerFilter$AjcClosure1.run(AnalyzerFilter.java:1)
at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
at org.joget.commons.util.AnalyzerAspect.analyzeRequests(AnalyzerAspect.java:54)
at org.joget.commons.util.AnalyzerFilter.doFilter(AnalyzerFilter.java:17)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:122)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:48)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:120)
at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:53)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:344)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:261)
at org.joget.commons.spring.web.CustomDelegatingFilterProxy.doFilter(CustomDelegatingFilterProxy.java:30)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:85)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Caused by: org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2198)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1927)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:255)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:562)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:420)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:305)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.extract(ResultSetReturnImpl.java:82)
... 193 more
ERROR 16 nov. 2015 16:52:27 org.joget.apps.datalist.model.DataList - Error retrieving binder row count
at org.hibernate.loader.hql.QueryLoader.iterate(QueryLoader.java:520)
at org.hibernate.hql.internal.ast.QueryTranslatorImpl.iterate(QueryTranslatorImpl.java:428)
at org.hibernate.engine.query.spi.HQLQueryPlan.performIterate(HQLQueryPlan.java:322)
at org.hibernate.internal.SessionImpl.iterate(SessionImpl.java:1365)
at org.hibernate.internal.QueryImpl.iterate(QueryImpl.java:70)
at org.joget.apps.form.dao.FormDataDaoImpl.internalCount(FormDataDaoImpl.java:372)
at org.joget.apps.form.dao.FormDataDaoImpl.count(FormDataDaoImpl.java:331)
at sun.reflect.GeneratedMethodAccessor154.invoke(Unknown Source)
at org.joget.apps.app.service.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:17)
... 173 more
ERROR 16 nov. 2015 16:52:28 org.hibernate.engine.jdbc.spi.SqlExceptionHelper - ERROR: current transaction is aborted, commands ignored until end of transaction block
ERROR 16 nov. 2015 16:52:28 org.joget.apps.datalist.model.DataList - Error retrieving binder row count
... 173 more
ERROR 16 nov. 2015 16:52:40 org.hibernate.engine.jdbc.spi.SqlExceptionHelper - ERROR: current transaction is aborted, commands ignored until end of transaction block
ERROR 16 nov. 2015 16:52:40 org.joget.apps.form.service.FormService - Error executing store binder
at org.hibernate.persister.entity.AbstractEntityPersister.getDatabaseSnapshot(AbstractEntityPersister.java:1533)
at org.hibernate.engine.internal.StatefulPersistenceContext.getDatabaseSnapshot(StatefulPersistenceContext.java:317)
at org.hibernate.engine.internal.ForeignKeys.isTransient(ForeignKeys.java:255)
at org.hibernate.event.internal.AbstractSaveEventListener.getEntityState(AbstractSaveEventListener.java:521)
at org.hibernate.event.internal.DefaultSaveOrUpdateEventListener.performSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:100)
at org.hibernate.event.internal.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:90)
at org.hibernate.internal.SessionImpl.fireSaveOrUpdate(SessionImpl.java:684)
at org.hibernate.internal.SessionImpl.saveOrUpdate(SessionImpl.java:676)
at org.joget.apps.form.dao.FormDataDaoImpl.internalSaveOrUpdate(FormDataDaoImpl.java:476)
at org.joget.apps.form.dao.FormDataDaoImpl.saveOrUpdate(FormDataDaoImpl.java:460)
at com.sun.proxy.$Proxy28.saveOrUpdate(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.storeFormData(AppServiceImpl.java:1438)
at org.joget.apps.app.service.AppServiceImpl.storeFormData(AppServiceImpl.java:1373)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:201)
at com.sun.proxy.$Proxy51.storeFormData(Unknown Source)
at org.joget.apps.form.lib.DefaultFormBinder.store_aroundBody14(DefaultFormBinder.java:85)
at org.joget.apps.form.lib.DefaultFormBinder.store_aroundBody15$advice(DefaultFormBinder.java:94)
at org.joget.apps.form.lib.DefaultFormBinder.store(DefaultFormBinder.java:1)
at org.joget.apps.form.lib.WorkflowFormBinder.store_aroundBody12(WorkflowFormBinder.java:97)
at org.joget.apps.form.lib.WorkflowFormBinder.store_aroundBody13$advice(WorkflowFormBinder.java:94)
at org.joget.apps.form.lib.WorkflowFormBinder.store(WorkflowFormBinder.java:1)
at org.joget.apps.form.service.FormServiceImpl.recursiveExecuteFormStoreBinders(FormServiceImpl.java:521)
at org.joget.apps.form.service.FormServiceImpl.executeFormStoreBinders(FormServiceImpl.java:491)
at org.joget.apps.form.service.FormServiceImpl.submitForm_aroundBody0(FormServiceImpl.java:286)
at org.joget.apps.form.service.FormServiceImpl$AjcClosure1.run(FormServiceImpl.java:1)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96cproceed(AbstractTransactionAspect.aj:66)
at org.springframework.transaction.aspectj.AbstractTransactionAspect$AbstractTransactionAspect$1.proceedWithInvocation(AbstractTransactionAspect.aj:72)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96c(AbstractTransactionAspect.aj:70)
at org.joget.apps.form.service.FormServiceImpl.submitForm(FormServiceImpl.java:260)
at com.sun.proxy.$Proxy26.submitForm(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.submitForm(AppServiceImpl.java:1241)
at com.sun.proxy.$Proxy51.submitForm(Unknown Source)
at org.joget.apps.form.lib.SubmitButton.actionPerformed_aroundBody6(SubmitButton.java:36)
at org.joget.apps.form.lib.SubmitButton.actionPerformed_aroundBody7$advice(SubmitButton.java:94)
at org.joget.apps.form.lib.SubmitButton.actionPerformed(SubmitButton.java:1)
at org.joget.apps.form.service.FormUtil.executeActions(FormUtil.java:572)
at org.joget.apps.form.service.FormUtil.executeActions(FormUtil.java:580)
at org.joget.apps.form.service.FormServiceImpl.executeFormActions(FormServiceImpl.java:438)
at com.sun.proxy.$Proxy26.executeFormActions(Unknown Source)
at org.joget.plugin.enterprise.CrudMenu.submitDataForm_aroundBody44(CrudMenu.java:526)
at org.joget.plugin.enterprise.CrudMenu.submitDataForm_aroundBody45$advice(CrudMenu.java:94)
at org.joget.plugin.enterprise.CrudMenu.submitDataForm(CrudMenu.java:1)
at org.joget.plugin.enterprise.CrudMenu.submitForm_aroundBody40(CrudMenu.java:361)
at org.joget.plugin.enterprise.CrudMenu.submitForm_aroundBody41$advice(CrudMenu.java:94)
at org.joget.plugin.enterprise.CrudMenu.submitForm(CrudMenu.java:1)
at org.joget.plugin.enterprise.CrudMenu.handleForm_aroundBody36(CrudMenu.java:306)
at org.joget.plugin.enterprise.CrudMenu.handleForm_aroundBody37$advice(CrudMenu.java:94)
at org.joget.plugin.enterprise.CrudMenu.handleForm(CrudMenu.java:1)
at org.joget.plugin.enterprise.CrudMenu.getJspPage_aroundBody22(CrudMenu.java:129)
at org.joget.plugin.enterprise.CrudMenu.getJspPage_aroundBody23$advice(CrudMenu.java:94)
at org.joget.plugin.enterprise.CrudMenu.getJspPage(CrudMenu.java:1)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody12(UserviewMenu.java:132)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody13$advice(UserviewMenu.java:94)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage(UserviewMenu.java:1)
at org.joget.apps.userview.service.UserviewUtil.getUserviewMenuHtml(UserviewUtil.java:91)
at org.joget.apps.userview.service.UserviewThemeProcesser.getContent(UserviewThemeProcesser.java:551)
at org.joget.apps.userview.service.UserviewThemeProcesser.getHtml(UserviewThemeProcesser.java:166)
... 204 more
joget.out :
... 193 more
... 173 more
... 173 more
... 204 more
help is needed...
thanks
Frederic
