Hi Shaker,
I'm not sure what is expected as there isn't enough information. The log output given looks like debugging information related to the LDAP Directory Manager, and is unrelated to the SOAP Tool.
By the way, noticed that you have asked a lot of similar or duplicate questions. It would be better not to do that and to ask questions with sufficient information for others to help you. A good reference on how to do this is available on Stack Overflow at http://stackoverflow.com/help/mcve.
Best Regards
Julian- shaker alzoubi
I noticed that splitting each problem in different question is more efficient, to get specifc answers.
either when select the debug mode or without,
there is no output the describe whats going on while calling a webservice method through the SOAP tool
below is the results.
INFO 23 Nov 2016 08:42:00 org.joget.plugin.ldap.RoleDaoLDAPImpl - Is Admin: true
INFO 23 Nov 2016 08:42:03 org.joget.workflow.shark.WorkflowAssignmentManager - [processId=68_soapToolSample_process1, processDe
fId=soapToolSample#1#process1, participantId=participant1, next user=[shakerz]]
INFO 23 Nov 2016 08:42:04 org.joget.plugin.ldap.UserDaoLDAPImpl - getUser(username:shakerz)
INFO 23 Nov 2016 08:42:04 org.joget.plugin.ldap.UserDaoLDAPImpl - filter: (&(objectClass=person)(sAMAccountName=shakerz))
INFO 23 Nov 2016 08:42:04 org.joget.plugin.ldap.RoleDaoLDAPImpl - check user :shakerz is an admin or not.
INFO 23 Nov 2016 08:42:04 org.joget.plugin.ldap.RoleDaoLDAPImpl - filter: (&(|(sAMAccountName=k2admin)(sAMAccountName=shakerz))
(distinguishedName=CN=Shaker Al-Zoubi,OU=Users,OU=IT,OU=Main Branch,DC=fastlink,DC=com,DC=jo))
INFO 23 Nov 2016 08:42:04 DirectoryManagerLDAPImpl - Using paged search = true, Result pre page = 100
INFO 23 Nov 2016 08:42:04 DirectoryManagerLDAPImpl - Paged Search - Current Total Results Return : 1
INFO 23 Nov 2016 08:42:04 org.joget.plugin.ldap.RoleDaoLDAPImpl - Is Admin: true
INFO 23 Nov 2016 08:42:26 org.joget.plugin.enterprise.SoapTool - {}
INFO 23 Nov 2016 08:42:27 org.joget.workflow.shark.WorkflowAssignmentManager - [processId=68_soapToolSample_process1, processDe
INFO 23 Nov 2016 08:42:27 org.joget.plugin.ldap.UserDaoLDAPImpl - getUser(username:shakerz)
INFO 23 Nov 2016 08:42:27 org.joget.plugin.ldap.UserDaoLDAPImpl - filter: (&(objectClass=person)(sAMAccountName=shakerz))
INFO 23 Nov 2016 08:42:27 org.joget.plugin.ldap.RoleDaoLDAPImpl - check user :shakerz is an admin or not.
INFO 23 Nov 2016 08:42:27 org.joget.plugin.ldap.RoleDaoLDAPImpl - filter: (&(|(sAMAccountName=k2admin)(sAMAccountName=shakerz))
INFO 23 Nov 2016 08:42:27 DirectoryManagerLDAPImpl - Using paged search = true, Result pre page = 100
INFO 23 Nov 2016 08:42:27 DirectoryManagerLDAPImpl - Paged Search - Current Total Results Return : 1
INFO 23 Nov 2016 08:42:27 org.joget.plugin.ldap.RoleDaoLDAPImpl - Is Admin: true
