Hi, there's not enough information to help. It would be good to read http://stackoverflow.com/help/how-to-ask on the way to ask a good question.
Hi Guys,
Hope you can help.
I need to Map workflow parameters to JSON POST Payload Parameters.
The values are not posted correctly.
Thanks,
Ernest.
Can you list down steps to replicate? There's no way to help you with the limited information you are giving. Cheers
In the JSON POST Tool, I needed to populate the as JSON Post Payload Parameters with the value of a workflow parameter. what I needed was the JSON Post Payload Parameter value populated with #variable.wfparentprocessId#. Thanks, I sorted this one!
