You can achieve this by using Database SQL Query Options.
Formerly known as JDBC Form Binder , Database SQL Queryallows you to use custom SQL statements to retrieve and load records into your form fields. Similarly, you can write SQL statements to save the records in your form field into a database table.Add your comment...
