Hi Thejaswi
The answer in Is there a way to export/import a joget form as an xls? might assist you on the above.
Hi Thejaswi
Can you give more examples or screenshot of your form action?
As you know, each form can have one or more sections, and these sections can be programmed to perform a specific load or save binder action on its own.
- Thejaswi Chindu
Hi Andrew, What i am working on is a kind of export/import functionality, wherein, there will be an export button somewhere in the form on click of which, i should get an excel file with all the fields/values (filled/unfilled) in the form. So, i was thinking of utilising the store binder capability of the form if i could trigger it by the click of this export button for instance.
I need to trigger load/store binder of a form by some other action which i take in the form (i dont want to save/submit the form). Is there a way to do this ?
