Hi everyone,
I have setup the configuration steps needed to use OpenID Connect Directory Manager Plugin to authenticate users to sign in to Joget. However, upon trying to login into Joget, it returns me error message, with the message log as below.
ERROR 16 Jul 2024 02:20:30 org.joget.commons.spring.web.CustomDelegatingFilterProxy - An exception occurred processing [/WEB-INF/jsp/ubuilder/v5view.jsp] at line [11]__8: %>_9: _10: <c:if test="${!empty processer}">_11: <c:set var="html" value="${processer.html}"/>_12: _13: <c:if test="${!empty processer.redirectUrl}">_14: <c:redirect url="${processer.redirectUrl}"/>___Stacktrace:
3503org.apache.jasper.JasperException: An exception occurred processing [/WEB-INF/jsp/ubuilder/v5view.jsp] at line [11]
Stacktrace:
    at org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:610) ~[jasper.jar:9.0.86]
    at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:499) ~[jasper.jar:9.0.86]
    at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:379) ~[jasper.jar:9.0.86]
    at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:327) ~[jasper.jar:9.0.86]
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:623) ~[servlet-api.jar:4.0.FR]
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:209) ~[catalina.jar:9.0.86]
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:153) ~[catalina.jar:9.0.86]
    at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51) ~[tomcat-websocket.jar:9.0.86]
Fyi, I used Issuer URL as below format:
https://login.microsoftonline.com/{tenant}/v2.0
I have tried to debug this issue, but have not been able to found the solution to it.
Any ideas on how I can make this works?
Thanks!
      Just so you are not missing any steps. >
      do ensure all steps are adhered according to the documentation :
        The error log is quite generic.
        If it is possible, can you attach the whole log file here?
        So we can have a broader perspective on this ?
