consider using the Report Builder Report Builder - Marketplace Knowledge Base - Joget | COMMUNITY
there's a sample app on how you can send parameters into the report builder
I need to show some text field value on header/footer in PDF. But it doesn't work when I set hash variable in export PDF tool. How could I export it ?
hello marcus,
for you use API report builder, can you get hash variable for show text field value
https://dev.joget.org/community/display/DX7/Hash+Variable
You can use the hash variable according to your needs.
thank you.
