form select input element
I dont want the random digits followed by my given id. which makes it difficult to attach any javascripts.
eg.
<select id="lead_type_10672147061629756511111141367357" name="lead_type">
                <option value="" grouping="">Select From The Below Field</option>
</select>
instead i want only id="lead_type" or whatever i give as id.
      Hi Mahe, You can use the Joget Javascript API to write your scripts.
      Please Refer: Javascript API
      Additionally you can select your Select boxes as show below:
      // Select using name attribute
      $("select[name='lead_type']").on("change", function() {
      const selectedValue = $(this).val();// your logic goes here
      Hope this helps!
