is there any possible way to change the HOD in the organizational directory to something else
rather than Set HOD i want it to be something else.
is possible please let me know how and from where to change
      Hi Tarek, to modify the HOD in the organizational directory, please update the following message key:
      console.directory.department.hod.set.label=Set Manager
      console.directory.department.hod.set.label.title=Set Manager
      console.directory.department.hod.set.label.confirmation=Are you sure you want to set this user as Manager?
      console.directory.department.hod.remove.label=Remove Manager
      console.directory.department.hod.remove.label.confirmation=Are you sure you want to remove Manager from this department?
      console.directory.department.common.label.hod=Manager
      The above message key can be found in: .\apache-tomcat-x.x.x\webapps\jw\WEB-INF\classes\console_en.properties
      Please be advised that it may be necessary to restart Apache Tomcat for the changes to take effect.
      For example, I changed the text from HOD to Manager
