primaryKeyValue is not a required parameter if you don't pass one it creates new record. if you pass a value and the value already exists it updates the existing record.
here is the catch if you pass a value that doesn't exists it will create a new record but the new row will have the next auto generated value not necessarily the value you passed.
Hi, isn't the primaryKeyValue a required parameter? I believe detailed error information is in the logs and not disclosed for security purposes.
I'm using JSON
API#web/json/data/form/store/(*:appId)/(*:formId)/(*:primaryKeyValue)
when I make an update I have to send the primaryKeyValue which works fine but when I need to add new row I don't need to send the primaryKeyValue the row gets created but the return that comes back doesn't include the primarykey. it come back like this
"id": ""
just that you know the id is auto generated.
plus how can we enhance the generic error code that I'm getting from SQL server
"message": "{\"error\":{\"formid\":\"Error storing data: could not execute statement\"}}" is there a way to get SQL server Error message displayed.
appreciate your help.
thanks.
