You'll need to use the SQL Update statement. Ensure the columns has a prefix "c_" and the table name has the prefix "app_fd_"
example: You have a form with the table named "projects", and in it you have a field called "status". Hence your SQL update statement should look something like:
UPDATE app_fd_projects SET c_status='Assigned' WHERE <whatever conditions set>;
more info at JDBC Form Binder
Now, I want to update status when I will click on assign button then selected checkbox's status value will be update to Assigned.
Thank you.
