not sure what you mean by "datalist PDF endpoint". Would you consider using datalist hash variable as an alternative? Hash Variable#DatalistHashVariable(New)
Hi Ian,
Thank you for response. I tried hash variable in email body and it works. But our requirement is to attach data list as PDF.
We take reference from link "Send Datalist as attachment in Email Tool". Its works fine and data list can be attached at PDF (Email tool attachments section) but stopped working as soon as we put permission on data list.
- Can we use HASH Variable to add data list as PDF (in email body or attachment section of email tool)? I tried same hash Variable as URL and System Path in attachments but no success. Please suggest if possible.
- Any thoughts on data list permission issue. Seems issue with scope of scheduler.
Best regards,
Amit
Hi Team,
I have to send data list as email at scheduled interval.
As data list contain sensitive info so can't be used without permission. Request your suggestion how datalist with permission can be used with scheduler.
Setup Details: Joget DX Enterprise (Version: 7.0.29 - build 29aa79a), Scheduler Menu (6.0.1)
Regards,
Amit
