Hi, for client-side validation yes you can add your own custom JavaScript within a Custom HTML element. On the server-side, you can add the validation code within a form validator, for example the BeanShell Validator.
Thank you Anders, I was confused that the validators are associated with a particular field, but it makes sense that you can test more than field in the Beanshell and choose to invalidate the submission that way.
I have a requirement where a form should only be able to be submitted if some combination of values are entered. For instance, the user must enter values in 3 out of 5 fields, or if they enter a value in field A then they must enter a value in field B.
Assuming there is a way to do this in javascript, I would also like the validation checked on the server side so that just disabling or hiding the submit button is not enough to bypass the validation. Any thoughts or pointers?
