Instead of toggling visibility of the section9, i suggest to move the content of section9 in a <template> element and leave section9 empty initially.
when gtotalCur >= 10000, clone the content of section9 from <template> tag into section9's <div> element
and when gtotalCur < 10000, remove the content of section9.
Example for js:
<script>
var section = $('#section9');
function removeMandatory() {
section.empty();
function addMandatory() {
template = $("#myInputs").clone();
section.append(template);
// remaining codes remains the same
</script>
Example for html:
<template id="myInputs">
<input type="text">
<select>
<option value="volvo">Volvo</option>
<option value="saab">Saab</option>
<option value="mercedes">Mercedes</option>
<option value="audi">Audi</option>
</select>
<textarea>
Awesome, you did it!
</textarea>
</template>
Thank you for your reply.
do you have any example which i can study to understand?
Hi.. just drop you with an example above, have a try!
Hi.. thanks for your reply and example.. i have tired putting this into a single Custom HTML field but it seem like its not working. I'm i doing something wrong?
<script>
section.empty();
// Function to check gtotalCur and toggle section visibility
function checkSectionVisibility() {
var gtotalCur = parseFloat($('input[name="gtotalCur"]').val().replace(/,/g, '')) || 0;
if (gtotalCur >= 10000) {
//$('#section9').show(); // Show section9 if gtotalCur >= 10000
addMandatory(); // Add mandatory attributes back
} else {
//$('#section9').hide(); // Hide section9 if gtotalCur < 10000
removeMandatory(); // Remove mandatory attributes
// Initial check on page load
checkSectionVisibility();
// Listen for changes on gtotalCur input field
$('input[name="gtotalCur"]').on('input change', function() {
</script>
<input type="text">
<select>
</select>
<textarea>
</textarea>
</template>
Hi, i suppose a working sample is more beneficial for you.
Make sure do not set Validator for any inputs you have in Section9, just leave it empty.
Hope you like it: APP_sample-for-dx7.jwa
Hi thank you for the sample. seem to be working now.
one more related question is it possible to convert this select box to a popup select box and the data is taken from the datalist?
I was wondering if there is a way to set a field to "Mandatory" if the section is visible. This needs to be set before any submission occurs, so I think the only way is to use custom HTML.
The built-in visibility control for DX7 cannot be set because it does not support the relational operator(greater than or less than), so I managed to create a custom HTML to show the hide section. Because this was done via custom, if a submission was done without the section visible, it shows "Validation Error." If I remove this mandatory checkbox, then the submission was successful.
Below is my custom HTML code. "Section 9" is the section that shows hide; within this section there is a select box field, which I wish to set to mandatory if visible via vice versa.
<script> $(document).ready(function() { // Function to remove mandatory attribute from fields in a specific section function removeMandatory() { var section = $('#section9'); // Target the specific section // Find all input fields, selects, and textareas within the section section.find('input, select, textarea').each(function() { $(this).prop('required', false); // Remove the required attribute console.log("Removed mandatory requirement from: " + $(this).attr('name')); // Log the removal }); } // Function to add mandatory attribute back to fields in a specific section function addMandatory() { var section = $('#section9'); // Target the specific section // Find all input fields, selects, and textareas within the section section.find('input, select, textarea').each(function() { $(this).prop('required', true); // Add the required attribute console.log("Added mandatory requirement to: " + $(this).attr('name')); // Log the addition }); } // Function to check gtotalCur and toggle section visibility function checkSectionVisibility() { var gtotalCur = parseFloat($('input[name="gtotalCur"]').val().replace(/,/g, '')) || 0; if (gtotalCur >= 10000) { $('#section9').show(); // Show section9 if gtotalCur >= 10000 addMandatory(); // Add mandatory attributes back } else { $('#section9').hide(); // Hide section9 if gtotalCur < 10000 removeMandatory(); // Remove mandatory attributes } } // Initial check on page load checkSectionVisibility(); // Listen for changes on gtotalCur input field $('input[name="gtotalCur"]').on('input change', function() { checkSectionVisibility(); }); }); </script>Thank you in advance
