The Calculation Field would sum up the whole column. But if you want to only sum up those "line == SG" then you will need to probably write Javascript and put into Custom HTML.
Spreadsheet Deep Customizations might helps too.
The account field is created to group all columns if the field is created to calculate "SG" so I would like each field to be a line in this, not a practical solution but this is there to make it
How to track price per line and background cell in "SG" group to save list data or see how much each line was spent and automatically need to indicate number of rows to calculate line price.
