Hi, I've noticed that you used a type mention for your list "<String>":
List<String> selectedValues = Arrays.asList(fieldValue.split(";"));
For which the Bean Shell does not recognize. See here for more info: Bean Shell Programming Guide#2.Donotneedtomentionthetypeofelementofacollections
It should just be:
List selectedValues = Arrays.asList(fieldValue.split(";"));
Another thing, I've realized that it seems you want to pass a workflow variable value instead, not formdata. Your code is used to get the form values from the database. To pass on wflow variables, see to this kb link: Setting Workflow Variable Value in Process Tool Bean Shell
There's also a plugin tool that you can use for a no-code way in the Joget marketplace: https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=WVariable_Update_Tool-1
thank you so much
you help me a lot
thanks again
java not running inside the tool process why ?
here the code the approversList stored from multiselect box multiple values and the firstSelectedValue intilized at the same form with initial value
i want to store the first approvers inside the firstSelectedValue variable, whats the wrong here, please ?
import org.joget.apps.form.service.FormService;
import java.util.Arrays;
import java.util.List;
import java.util.Map;
public class MultiSelectHandler {
public void handleMultiSelectField(FormData formData, FormService formService) {
// Get the multi-select field value from form data
String multiSelectFieldName = "approversList";
String fieldValue = formData.getFieldValue(multiSelectFieldName);
if (fieldValue != null && !fieldValue.isEmpty()) {
// Split the field value by semicolons to get a list of selected values
if (!selectedValues.isEmpty()) {
// Get the first selected value
String firstSelectedValue = selectedValues.get(0);
// Store or use the first selected value as needed
// For example, set it as a new value in the form data
formData.getFieldValues().put("firstSelectedApprover", firstSelectedValue);
// Optionally, log or further process the firstSelectedValue
LogUtil.info(MultiSelectHandler.class.getName(), "First Selected Approver: " + firstSelectedValue);
} else {
LogUtil.info(MultiSelectHandler.class.getName(), "No values found after splitting.");
} else {
LogUtil.info(MultiSelectHandler.class.getName(), "No values found in approversList.");
