You should use multirow form binder when using a formgrid if you want to access a value of a specific field later on. It will store the data in a separate form/table instead of storing it in a JSON format
hello everyone
i use a grid form
and the value of it saved as json
i need a field from json cause i use it in the process and initialize it as workflow variable
how to return it from json ? and how to use it inside the tool process ?
i do not put a json
but the form grid just saved it as a json
