Hi Christopher, Joget supports Progressive Web Applications (PWAs) by default, allowing you to install your Joget-based apps as mobile applications. Additionally, if you have a valid Joget license you can contact support to get APK / IPA that can be published in the Playstore. you can check out the Joget workflow mobile app in Playstore to get an idea.
Progressive Web Application - PWA
would like to know how to convert the form into mobile app? and able to access and open in mobile.
