Hi my problem is:
I would like to write a Beanshell script whice is deleting a Running process what I would.
But if i would like to delete the process manually in SHKActivites the mysql is throw an error massage beacuse oid and Activity is foreing key.
If somebody can copy the java script which is deleteing the Running processes? Because I can delete on Monitor Apps-> Running Process->Delete.
But i would the like to see the scipt behind the delete button. If somebody helps me i will post the full BeanShell code whice is deleting process.
Thank you,
Miklos
