Hi support,
I followed the below link to create a Dynamic Drop-Down List.
http://dev.joget.org/community/display/KBv4/Dynamic+Cascading+Drop-Down+List
I succeed with the first method by grouping but failed with the second method.by Options Binder.
I tired with the example from the link, the Options Binder could not link up the 2 select box "Type of leave" and "Category".
Whatever I choose in the "Type of leave" box, nothing would shows up in the "Category" box right away.
Also, I found another link which may able to do what I want,
http://dev.joget.org/community/display/KBv4/Ajax+Cascading+Drop-Down+List
But I could not find the options under Options Binder as it said so in the link, is that a Enterprise Edition Features?
Thanks a million.
Gilbert
Hi Gilbert,
Are you using v4? The AJAX support for cascading drop down lists should be available in the v4 Community Edition in v4 as well. As mentioned in Ajax Cascading Drop-Down List, the AJAX property option is currently available when using the following binders: BeanShell Options Binder, Default Form Options Binder and User Options Binder.
