HI all, i've try to install joget workflow on centos 5.4 machine, i've follow the readme instruction on the installer.. but i cannot start joget. i tried to start from the tomcat manager it's show error :
FAIL - Application at context path /wflow-wfweb could not be started
this is the log from catalina.out
Feb 11, 2011 1:10:52 PM org.apache.catalina.startup.ContextConfig start
FINE: org.apache.catalina.core.StandardContextValve/1.0
FINE: ======================
INFO 11 Feb 2011 13:10:57 org.joget.commons.util.SetupManager - Using base directory: /root/wflow/
INFO 11 Feb 2011 13:10:57 org.joget.commons.util.DynamicDataSource - datasourceName=workflow, url=jdbc:mysql://localhost:3306/wflowdb?characterEncoding=UTF-8, user=root
ERROR 11 Feb 2011 13:10:57 org.hibernate.util.JDBCExceptionReporter - Cannot create PoolableConnectionFactory (Access denied for user 'root'@'localhost' (using password: NO))
ERROR 11 Feb 2011 13:10:57 org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'setupSessionFactory' defined in class path resource [commonsApplicationContext.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1336)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:471)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:220)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:423)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4342)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:627)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:553)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:488)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1149)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:57)
at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39)
at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:426)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:128)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2073)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1298)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:814)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:732)
at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1367)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1333)
... 39 more
Feb 11, 2011 1:10:57 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/wflow-wfweb] startup failed due to previous errors
Feb 11, 2011 1:10:57 PM org.apache.catalina.startup.ContextConfig stop
FINE: ContextConfig: Processing STOP
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.ContextConfig init
FINE: ContextConfig: Initializing
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.ContextConfig processContextConfig
FINE: Processing context [/wflow-designerweb] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Successfully processed context [/wflow-designerweb] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Processing context [/wflow-designerweb] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf Catalina/localhost/context.xml.default
FINE: Processing context [/wflow-designerweb] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf/Catalina/localhost/wflow-designerweb.xml null
FINE: Successfully processed context [/wflow-designerweb] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf/Catalina/localhost/wflow-designerweb.xml null
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.ContextConfig start
FINE: ContextConfig: Processing START
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.ContextConfig processDefaultWebConfig
FINE: Processing context [/wflow-designerweb] web configuration resource file:///data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf/web.xml
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.ContextConfig applicationWebConfig
FINE: Parsing application web.xml file at jndi:/localhost/wflow-designerweb/WEB-INF/web.xml
FINE: Pipeline Configuration:
FINE: Processing context [/manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Successfully processed context [/manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Processing context [/manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf Catalina/localhost/context.xml.default
FINE: Processing context [/manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/webapps/manager/META-INF/context.xml null
FINE: Successfully processed context [/manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/webapps/manager/META-INF/context.xml null
FINE: Processing context [/manager] web configuration resource file:///data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf/web.xml
FINE: Parsing application web.xml file at jndi:/localhost/manager/WEB-INF/web.xml
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.ContextConfig authenticatorConfig
FINE: Configured an authenticator for method BASIC
FINE: org.apache.catalina.authenticator.BasicAuthenticator/1.0
FINE: Processing context [/host-manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Successfully processed context [/host-manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Processing context [/host-manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf Catalina/localhost/context.xml.default
FINE: Processing context [/host-manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/webapps/host-manager/META-INF/context.xml null
FINE: Successfully processed context [/host-manager] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/webapps/host-manager/META-INF/context.xml null
FINE: Processing context [/host-manager] web configuration resource file:///data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf/web.xml
FINE: Parsing application web.xml file at jndi:/localhost/host-manager/WEB-INF/web.xml
FINE: Processing context [] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Successfully processed context [] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18 conf/context.xml
FINE: Processing context [] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf Catalina/localhost/context.xml.default
FINE: Processing context [] configuration file /data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/webapps/ROOT/META-INF/context.xml null
FINE: Processing context [] web configuration resource file:///data/joget/joget-linux-2.0.1/apache-tomcat-6.0.18/conf/web.xml
FINE: Parsing application web.xml file at jndi:/localhost/WEB-INF/web.xml
Feb 11, 2011 1:10:58 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Feb 11, 2011 1:10:58 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Feb 11, 2011 1:10:58 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/25 config=null
Feb 11, 2011 1:10:58 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 6869 ms
i've confused for the one that's i've bold... any body can help me please...
thank's in adviced..
It seems that it has problem connecting to the database. The log shows the credential used when connecting to the database is wrong. Can you try to verify if the connection to the database is working?
Hope it helps!
pendekar
well. i used in localhost.. and mysql is up and running... what should i do to chek the connection..?
There's a page in the Knowledge Base on Installing Joget 2.0 on Ubuntu Linux 10.04 which you might find useful. Granted it's slightly different on Ubuntu, but the general steps are the same, especially the part on setting up the database.
