Hi there.
We are about to use joget for the first time and I watched the movies and read KBs. But there are questions for me that I like to have explained.
First I created a more complex workflow out of the blue with some remarks of our team of features the WF should have.
These are the remarks we found.
Case 1 – No File was uploaded
On Windows Edition:
We inserted many different files into a file field.
Small and big files, in every case there was no problem even uploading 50mb files.
We use joget on a windows server2008.
Trying to open the attachment is not possible, we get a 404 error screen.
The URL just looks like that, it seems to be a problem with the “null” part and the dot behind the file name.
Update: The file is also not in the specified upload folder. We definded one in the settings without any change.
Case 2 – Mandatory fields in read only sub forms are validated
We created one form with some sub forms. Always one of the sub forms are not read only, but they are there for informational purpose. If there is a mandatory field in a sub form that is read only, it is validated and blocks the process. “Please fill out all necessary fields”. We can’t, the sub form is read only.
Is there a way to bypass this validation if the sub form is read only without creating a second form where it is not mandatory?
Case 3 – Case overview
Is there a way to show a specific form to have an overview of the process instance even if it’s finished or running? We could need this for project meetings or emergency meetings.
Case 4 – JSON API doesn’t need authorization
We set the master user and password for the JSON API.
If we don’t use it in the json url, it works.
If we set it in the url, it works.
If we set it incorrectly, it works.
We don’t want to give full access. Does the API use the normal login if the master password is incorrect or not used in the url?
Case 5 - Use a title field in Inbox
An inbox contains the process type but not a “title”, so there can be 3 processes of the same type and you can’t divide them. How can you add a custom column to the inbox?
Case 6 – Duplicate a WF in an App
We are using very similar but different WF’s in one App. Sometimes we have to adjust an WF for a special request. If we use versions, we update every instance of one WF. Is it possible to duplicate the Workflow?
Case 7 – Escalation after getting a task
Escalations happen (ie 2h) after a task gets into that inbox. Can we change the duration of the inbox if the person accepts the tasks, or smthng. Like that? If the task is at already work, the escalation shouldn’t start at the moment the person gets the job, it should start if the person took too long.
Case 8 – Use variables in SLA, tools and exceptions
May we use form variables in SLA, tools and excetions? We would like to use a multivalue field with recieptiens for a mail and send informations to them after the form is triggered. We would like to let the project management enter the sla and exection duration for later steps.
Case 9 – Create an exception over a loop
If we have loops in our workflow, is it possible to realize an exception that starts before the loop and uses an exception if the process is stuck too long in the loop of steps?
Case 10 – Download files without sub form
How do you use a file uploaded in a former step without a sub form? You cannot use a workflow variable to show the files.
Case 11 – Send uploaded files as attachments
How can we send uploaded files as attachments in an email tool? Or how do we send Links to a file?
Yours sicerely,
Daniel
6 Comments
Hi Daniel,
Wow looks like a very comprehensive evaluation indeed :) Will try to answer your queries below
Hmm I've tried but could not replicate the problem. Have you tried using the file uploads in the sample or reference apps to see if it works?
Currently there's no way to bypass this validation. If it's a mandatory field, shouldn't there definitely be a value for it? If not, could it be marked as non-mandatory?
Do you mean a graphical view of the process instance? This feature is available for the administrator in the Web Console. When viewing a specific process instance under Monitor Apps, there's a "View Graph" button that will generate an image of the process.
If you don't provide a master login, the JSON API result will return a result anyway, but it's based on the current user making the request. The master login is only used when you need to retrieve information on behalf of another user.
There's a couple of ways to do this. You could use the DataList Inbox (http://dev.joget.org/community/display/KB/Datalist+Inbox+Userview+Menu+%28Inbox+with+Form+Data%29), which allows the flexibility when displaying columns.
Another possible approach is to use hash variables (http://dev.joget.org/community/display/KB/v3+Hash+Variables) in your process or activity names so that you could incorporate a title or reference number, for example.
For each app, you can have more than one process. In the Workflow Designer, you can right click on the process name on the left, and choose the "Duplicate" option to create a duplicate of the selected process.
Currently, deadlines are only calculated based on when a task is assigned.
You can use form data by making use of hash variables (http://dev.joget.org/community/display/KB/v3+Hash+Variables). For example, you could use #form.table_name.customer_email# in an Email Tool recipient. Hash variables are not supported for SLA though.
You could perhaps use a workflow variable to keep track of the status or number of iterations in your process. Then have a route that checks the value of the workflow variable before looping back.
You can just use a File Upload field, and give it the same ID as the previous field used in a former step. This will make it link back to the same file.
Currently, there's no built-in plugin to send uploaded files as an attachment. It's possible to develop a plugin for this (http://dev.joget.org/community/display/KB/Extending+Functionality+-+Developing+Plugins).
Alternatively, perhaps you design a form in a userview that contains the file upload, and link to that form instead.
Daniel Cremers
Hi Julian!
Thank you very much! Some cases cleared over time, and some
Case 1 – No File was uploaded - Solved
We tested that on a windows server version, the linux installation is alright. That fits for us.
I would like to show some subforms, even if they are not filled yet. To avoid making two forms (one with mandatory fields, one non-mandatory and readonly) I thought that would be fine showing one subform in all cases and only mark them as readonly or not. Is there a way to insert any javascript, that could do that (or smthng else)?
No, I would like to show a form of a finished process that shows some contents of the process like subforms and files. So users can access the informations of the process even if it's finished a year ago.
Case 4 – JSON API doesn’t need authorization - Solved
Thank you, that was a little confusing at the first time. :)
Case 5 - Use a title field in Inbox - Solved
Thank you, I'll have a try on that!
It will only duplicate the xpdl, but not the user, tool and form references?
Case 7 – Escalation after getting a task - Solved
Ok.
Case 8 – Use variables in SLA, tools and exceptions - Solved
How could I realize an exeption, that works, if the whole loop is done more that 2 days?
Case 10 – Download files without sub form - Solved
Thank you, I must have done smthng wrong...
Is it possible to create a download link of a file?
Thank you for your time!
Daniel
Hi Daniel,
Great to hear that many of the cases are clarified :)
Just to follow up on some of the others:
To avoid making two forms, it is possible to insert JavaScript using a Custom HTML element. This element allows you to place any HTML, so you can put your code within <script> tags there.
Oh, this requirement can be met by the way you design the processes, forms and lists in your app. For an example of this, maybe you can have a look at the HR Expenses Claim App (http://marketplace.joget.org/v3/v3enterprise/hr-expenses-claim-app.html). In this reference app, each expense claim has a status, and as the process runs the status of the claim gets updated accordingly. The user will be able to view the claims (current and historical) categorized according to status, and some forms will be read-only (e.g. those pending approval).
Yes, that only duplicates the process. The participants, activities and tools will need to be mapped separately.
For handling those types of exceptions, you can make use of deadlines to handle reminders and escalations, as described in Deadlines and Escalations
Not directly, I think the best bet would be through a form containing the file upload field.
Cheers!
Daniel Cremers
Hi julian.
That should work for me :) Thx.
And I'll have a closer look at that. Thank you.
So I can only set deadlines to one activity and not to a bunch of activities? I.e. saying 2 sequential tasks may take 2 hours in total?
Do I have to build a User View for that, or can I use the action forms?
Thank you!
Daniel Cremers
Anyone?
Case 9: Deadlines are set at either activity level or at process level. Not at a collection of activities.
The workaround is to not hard code the deadline value but instead, refer it to a workflow variable.
In "Duration Unit", choose Date or DateTime. Next, in Deadline limit, key in the Workflow Variable name.
Case 11: Design a process, with a activity followed by a tool. In the activity, choose the file to be uploaded. In the tool, execute codes to send out Email with attachments.
