Hi All,
Trying to compile the latest Beta 3 source but I am getting the following error, also searching for that file manually on Maven doesnt seem to find it either?
Regards
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.joget:wflow-wfengine:jar:3.0-BETA
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.joget -DartifactId=wflow-wfengine -Dversion=3.0-BETA -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.joget -DartifactId=wflow-wfengine -Dversion=3.0-BETA -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.joget:wflow-core:jar:3.0-BETA
2) org.joget:wflow-wfengine:jar:3.0-BETA
1 required artifact is missing.
for artifact:
from the specified remote repositories:
central (http://repo1.maven.org/maven2)
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 22 seconds
[INFO] Finished at: Wed Aug 31 15:50:40 BST 2011
[INFO] Final Memory: 9M/22M
root@bpms:/tmp/jogetworkflow-jw-community-223d717/wflow-core#
Hi David, you only need to build from wflow-app. Try to run mvn clean install in /wflow-app and you will get the following builds:
David Eales
Hi Tiensoon,
I had more joy attempted to compile under windows, i followed your advice and built from wflow-app which sucessfully built jw.war however jwdesigner.war had not been built, when I run mvn install in the wflow-designerweb folder I get the following:
[INFO] [dependency:copy
[INFO] Configured Artifact: org.joget:wflow-designer:3.0-BETA:jar
Downloading: http://repo1.maven.org/maven2/org/joget/wflow-designer/3.0-BETA/wfl
ow-designer-3.0-BETA.jar
[INFO] Unable to find resource 'org.joget:wflow-designer:jar:3.0-BETA' in reposi
tory central (http://repo1.maven.org/maven2
[ERROR] BUILD ERROR
[INFO] Unable to find artifact.
Embedded error: Unable to download the artifact from any repository
mvn install:install-file -DgroupId=org.joget -DartifactId=wflow-designer -Dv
mvn deploy:deploy-file -DgroupId=org.joget -DartifactId=wflow-designer -Dver
d]
[INFO] Total time: 53 seconds
[INFO] Finished at: Mon Sep 05 23:47:53 BST 2011
[INFO] Final Memory: 14M/35M
You shouldn't be building wflow-designerweb unless you have the need to do so. If you can look at it's pom.xml file. There is a list of dependency that you will need to have them ready beforehand.
Did you bump into any sort of error while building wflow-app? By right, it should produce both jw.war and jw-designer.war at the end of the building process. Try to run it again and observe the output.
Ahmed Khalil ABUABDOU
