In first activity, i have set the workflow variable to XXX. How in the activity, get the value of workflow variable ?
I have used #varibale.myworkflowVar#, but it not worked.
Thank's
Thank's
Hi Mohamed,
I think you have a typo there. The correct syntax for it is #variable.[variable_name]# and not #varibale.[variable_name]#
Mohamed
Hi Hugo,
Thanks bu I put the correct syntax but it does not work. When I display the variable in the fields of my form is still empty.
Let me explain my context :
In the first actrivity (participiant A), i have a form with id = 1. I filled a field with a value XXX that i passed to the next activity (participiant B) by using :
#variable.myvariable# and #form.myform.myField#
In the second activity (particiant B), i have a other form with id = 2 and il want to get the previous value (XXX) from the previous activity in the filed of the current form. by getting
#variable.myvariable# and #form.myform.myField# in my form.
It's not works, both are empty.
Any idea ?
Regards
Mohamed
Now, it's works. I resolved the problem.
I forgot to use "Form Builder" in my form process when i store my form.
Regards
Glad it works!
Xeless IT
Mohamed how could you solve this problem? How did you mean you had forgotten to use "Form Builder? I was fighting this problem 2 days ago. The situation almost the same and i can't get workflow variables and form field values neither. I am sure i missed something but i don't know what is the missing step.
Any help would be appriciated.
Thanks Zoltan
