I'm a Joget noob but I'm trying to change that. :)
As I'm trying to build some application, I have the following scenario that I can't achieve. Perhaps you could give me a hand.
In the main form, I need to select a field based on which a set of values can be chosen from or another set of values. In other words, if I select A, then another select box will be available to select "type A" values, if I select B, then another select box will be available to select "type B" values.
Thanks in advance!
Bastiana
See http://dev.joget.org/community/display/KB/Dynamic+Cascading+Drop-Down+List
