Works fine! I used the Windows Bundle with MySql and Java and it installed just fine on a Windows 2008 64bit - Virtual Private Server. No issues. Runs fast / well. I tried to get it working on a VPS with CentOS but I always had a database timeout issues. Seems to work well on Windows.
I think there's also variant of 64 bits of Tomcat as well but the default 32 bit Tomcat Joget default installer is using would work just fine on 64 bits machine although it may not take advantage of the larger memory addressing allocation though!
As far as I'm concerned, it should just install normally. Can you please try to install it on your machine and give us some feedback?
Paul
Good to hear from you again!
