Hi
Wenn I try to deploy and start the wflow-wfweb.war I get following error in my log file.
SCHWERWIEGEND: Error listenerStart
16.02.2011 22:25:29 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Context [/wflow-wfweb] startup failed due to previous errors
16.02.2011 22:25:29 org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
SCHWERWIEGEND: The web application [/wflow-wfweb] registered the JBDC driver [com.mysql.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
16.02.2011 22:25:29 org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SCHWERWIEGEND: The web application [/wflow-wfweb] appears to have started a thread named [Timer-2] but has failed to stop it. This is very likely to create a memory leak.
SCHWERWIEGEND: The web application [/wflow-wfweb] appears to have started a thread named [Thread-11] but has failed to stop it. This is very likely to create a memory leak.
INFO 16 Feb 2011 22:27:38 org.joget.commons.util.SetupManager - Using base directory: /usr/share/tomcat6/wflow/
ERROR 16 Feb 2011 22:27:38 org.joget.commons.util.DynamicDataSourceManager - Error creating default profile
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:900)
at org.joget.commons.util.DynamicDataSourceManager.createDefaultProfile(DynamicDataSourceManager.java:304)
at org.joget.commons.util.DynamicDataSourceManager.getCurrentProfile(DynamicDataSourceManager.java:162)
at org.joget.commons.util.DynamicDataSourceManager.getProperties(DynamicDataSourceManager.java:45)
at org.joget.commons.util.DynamicDataSource.createDataSource(DynamicDataSource.java:19)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:82)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:84)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2073)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1298)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:814)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:732)
at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1367)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1333)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:471)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:220)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:423)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4135)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4630)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1276)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:624)
at org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:136)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:563)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:636)
ERROR 16 Feb 2011 22:27:39 org.hibernate.util.JDBCExceptionReporter - Cannot create PoolableConnectionFactory (Access denied for user 'root'@'localhost' (using password: NO))
ERROR 16 Feb 2011 22:27:39 org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'setupSessionFactory' defined in class path resource [commonsApplicationContext.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1336)
Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:57)
at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39)
at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:426)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:128)
... 35 more
16.02.2011 22:27:39 org.apache.catalina.core.StandardContext start
16.02.2011 22:27:39 org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
16.02.2011 22:27:39 org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SCHWERWIEGEND: The web application [/wflow-wfweb] appears to have started a thread named [Timer-3] but has failed to stop it. This is very likely to create a memory leak.
SCHWERWIEGEND: The web application [/wflow-wfweb] appears to have started a thread named [Thread-13] but has failed to stop it. This is very likely to create a memory leak.
Manuel E.
I have tried to grant privileges several times
| GRANT ALL PRIVILEGES ON *.* TO 'root'@'localhost' IDENTIFIED BY PASSWORD '*81F5E21E35407D884A6CD4A731AEBFB6AF209E1B' WITH GRANT OPTION |
| GRANT ALL PRIVILEGES ON `wflowdb`.* TO 'root'@'localhost'
Hi, looks like there could be a couple of problems. Firstly, it looks like Tomcat might not have sufficient privileges to create a directory to store configuration information:
Once that's sorted out, there's a page in the Knowledge Base on Installing Joget 2.0 on Ubuntu Linux 10.04 that you might find useful. Hope this helps!
