I am very new at this and trying to do the Travel Request Form tutorial. I've done everything exactly as in the video (twice over now) but when I try to run the process from the Processes page it never reaches the second activity. I can fill out the travel request form but it does not then continue to the approval form. The window simply closes, not letting me get any further.
Hi Kevin,
Thanks for trying out Joget, you may try to check in your Running Processes, click on the process instance, then on the second activity (Viewing a Running Activity Instance), check the "Pending" field to see who is assigned to next.
Then, login as that person, click on its Inbox to access the assignment.
Kevin
Yup, that was it. Thanks! I Knew if it was a simple problem it had a simple answer!
