I tried the 2 JavaScript sample in the following links, but none of them work.
http://dev.joget.org/community/display/KBv4/Calculate+Date+Range
http://dev.joget.org/community/display/KBv4/Date+Picker+-+Compare+Date
Those code were put into a Custom HTML field within a form, and I had changed the related date picker field to the names according to the sample shows.
Is there any thing else i need to do beside just copy the code in the Custom HTML field?
Gilbert
Ashutosh Tripathi
Hello Gilbert,
I tried the sample, but in my case it works fine. Let me put down the steps for you again:
1.Add two datePickers with ids : 'fromDatepicker' & 'toDatepicker'
2.Add a textField with id : 'days'
3.Add a customHTML field to the form and between the <script type="text/javascript"></script> tags, paste the contents of the script given in the URL: Calculate Date Range.
Hope this helps,
Ashutosh
thang
Please help me this case.
I used the same code given and it works. However, the result is not quite ok. If I select start_date is 01.01.2016 and end_date is 01.01.2016 then the result is 0. Well the result should be 1.
Second, the code should not calculate the weekend as well.
Please help
Thank you
