I need to write a javascript script that reads a calucaltion field in order to show a text but i'm not sure how to point the calculation field itself.
Eg. Calculation field: 2,45 --> (flooring: 2)
Text Shown: RELEVANT IMPACT
Calculation field: 1,23 --> (flooring: 1)
Text Shown: LOW IMPACT
Calculation field: 4,00
Text Shown: MASSIVE IMPACT
Thanks for your help
Hi Roberto,
You will need to write your own javascript coding to retrieve values from Joget's Form, and to put them into a Custom HTML. Remember to code your script such that it will listen to the affected fields.
Good luck.
