May i ask what is the function of service level monitor in inbox? And how should i do to make use of this function? Thank you.
It is for SLA implementation on the activities. You may implement SLA by modifying your process in the Workflow Designer by specifying the SLA limit in the activities you would like to have SLA enforced.
Hodjat Toraby
Hi, is it possible to have more detail with example.
Your description was not enough and I also could not understand that. Can you display about SLA in action?
With best regards
Izzah Hazwani
untuk SLA memang xboleh guna dgn route ke..?
Hi guys,
You may refer to the documentation that I have just created at Process Deadlines, Exceptions and SLAs. Hope this helps.
