I wrote a javaScript which will call one of the JSON API web services when the user click on a button , so i wrote the following inside a custom HTML field on the Joget form builder, but nothing will be displayed when the user click on the button and only the #title will be changed.
<script language="JavaScript">
function test () {
$.ajax({
url: "http://localhost:8080/jw/web/json/workflow/package/list",
type: "GET",
cache: false,
success: function (result) {
$('#products').empty();
$('#title').text("All Processes");
$.each(result.data, function (key, val) {
var str = val.packageName;
$('<li/>', { text: str })
.appendTo($('#products'));
</script>
<form name="myForm">
<input type="button"
value="Display alert box"
name="button1"
onClick="alert('You clicked the first button.')"><br>
value="Call on button 1"
name="button2"
onClick="test()">
<h1 id ="title"></h1>
<ul id="products">
</ul>
</form>
Can anyone advice how can i make my code works well . baring in mind that i run my code inside a visual studio web project and the above code worked well and the list of packages which were returned from the APi call were displayed successfully.
Hi BR,
You will need to add another parameter into your AJAX call to indicate that you are expecting a plain text response.
Try to run the following in your Firebug
$.ajax({ url: "/jw/web/json/workflow/package/list", type: "POST", dataType: "text", }).done(function(data) { obj = jQuery.parseJSON(data); $.each(obj.data, function (key, val) { var str = val.packageName; console.log(str); }); });Good luck!
BPMdesigner
Thanks for the reply. i tried
but still the javascript will not display the list of processes. but i have also these two questions:-
1. why i should define the dataType to be plain text, although the returned result from the call will be JSON?
2. i am calling a Get service ,, why i should defined type: "POST",
Thanks in advance for yuor help.
BPMdesigner
i changed thedata type to be
and the call worked fine.
Glad it helps. Welcome.
