Do you get the error setting the deadline in the Workflow Designer, or when it executes? I'm assuming you're getting the error during execution, so it might be helpful if you post the full errors (stack traces) and maybe your deadline settings?
Rudy Hartono
I got error when setting an asynchronous deadline. The error is something with "unexpectedRollbackException........" and "DeadlineChecker..."
Frans Thamura
where is the preference to save the XPDL to the server, from WF Designer?
F
Mahmoud AL Khatib
XPDL are saved by using "Upload Process XPDL File" in design new process,
if the XPDL is in the WF designer you use deploy (for new files) / update button(for existing files)
Frans Thamura reported about the following issue on 26th Aug:
This issue has now been resolved in the latest code base. Please refer to this changeset (GitHub) for further details.
