After reading the knowledge base article titled "Obtain data from external database"
I followed the instructions (added the select box and chose beanshell binder) and tried to populate the dropdown list with a FormRowSet object populated with FormRow objects using this code:
import org.joget.apps.form.model.*;
public FormRowSet test() {
FormRowSet f = new FormRowSet();
f.setMultiRow(true);
FormRow r = new FormRow();
FormRow rr = new FormRow();
r.put("test1","tester1");
rr.put("test2","tester2");
f.add(r);
f.add(rr);
return f;
return test();
The code gets executed when I go to the preview pane, but when it renders I get a bunch of json and not the drop down in the form I'm expecting. In the log file I see this error:
Oct 10, 2011 3:51:13 PM org.joget.apps.form.service.FormService previewElement
SEVERE: Error generating element html
java.util.NoSuchElementException: Hashtable Enumerator
at java.util.Hashtable$Enumerator.nextElement(Hashtable.java:1021)
at java.util.Hashtable$Enumerator.next(Hashtable.java:1032)
at org.joget.apps.form.service.FormUtil.getElementPropertyOptions(FormUtil.java:741)
at org.joget.apps.form.lib.SelectBox.getOptionMap(SelectBox.java:38)
at org.joget.apps.form.lib.SelectBox.renderTemplate(SelectBox.java:81)
at org.joget.apps.form.model.Element.render(Element.java:167)
at org.joget.apps.form.service.FormService.generateElementDesignerHtml(FormService.java:123)
at org.joget.apps.form.service.FormService.previewElement(FormService.java:54)
at org.joget.apps.form.service.FormService.previewElement(FormService.java:35)
at org.joget.apps.app.controller.FormBuilderWebController.previewElement(FormBuilderWebController.java:118)
Another odd thing. When I modify the code portion to only add a single FormRow to the FormRowSet (only call f.add(r) and comment out f.add(rr)) it seems to work. The preview shows my form with a single item in the drop down list.
So. My question is what am I doing wrong and how do I populate the drop down with multiple items from beanshell?
Andrew
Andrew
This is with the BETA2 release of v3 if that makes a difference.
Owen Ong
Hi Andrew,
The correct way to doing it is as below:
import org.joget.apps.form.model.*; import org.joget.apps.form.service.*; public FormRowSet test() { FormRowSet f = new FormRowSet(); f.setMultiRow(true); FormRow r1 = new FormRow(); r1.put(FormUtil.PROPERTY_VALUE, "test1"); r1.put(FormUtil.PROPERTY_LABEL, "tester1"); f.add(r1); FormRow r2 = new FormRow(); r2.put(FormUtil.PROPERTY_VALUE, "test2"); r2.put(FormUtil.PROPERTY_LABEL, "tester2"); f.add(r2); return f; } return test();Hope it's help.
Owen
Andrew
That is exactly what I needed. Thank you!
Hafizuddin Husain
thanks too. really help.
