Somebody can show me a working examle code, where are using a checkbox list with beanshell and in the beanshell getting a workflow variable to local variable?
If I using in a textbox #variable.test#, i write this parameter to the textbox field i see the correct value, but in a beanshell can't use this.
Joget 2.0.3 with mysql
I'am trying this:
String test1 = new String("#variable.test#");
PreparedStatement stmt = con.prepareStatement("SELECT id, c_SzKor_Nev from formdata_Jogosultsagok_BF WHERE c_Szolg_Id LIKE 'SAP' and c_user_name = '"test1"' "); // SQL query
this:
http://dev.joget.org/community/display/FORUM/workflow+variable\
this:WorkflowManager workflowManager = (WorkflowManager) pluginManager.getBean("workflowManager");
String usernames = workflowManager.getProcessVariable(workflowActivity.getProcessId(), "test"); /
But nor working...I can't get a variable value.
Pls. Show me a working example. This is very important for us! THX
dimuthu suranga wijegunarathna
i also face same problem.is there any one know the solution for this problem?
Dimuthu
