hi there i am having following error when building to wflow-app folder. please suggest me a solution
Tests in error:
testDeletion(org.joget.directory.model.service.TestDirectoryManager)
testOrganizationChart(org.joget.directory.model.service.TestDirectoryManager)
testUsersAndGroups(org.joget.directory.model.service.TestDirectoryManager)
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] wflow-jdbc ......................................... SUCCESS [ 1.630 s]
[INFO] wflow-commons ...................................... SUCCESS [ 0.609 s]
[INFO] wflow-plugin-base .................................. SUCCESS [ 3.988 s]
[INFO] wflow-plugin-archetype ............................. SUCCESS [ 0.865 s]
[INFO] wflow-directory .................................... FAILURE [ 12.797 s]
[INFO] wflow-wfengine ..................................... SKIPPED
[INFO] wflow-core ......................................... SKIPPED
[INFO] wflow-consoleweb ................................... SKIPPED
[INFO] wflow-designer ..................................... SKIPPED
[INFO] wflow-designerweb .................................. SKIPPED
[INFO] wflow-app .......................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20.514 s
[INFO] Finished at: 2014-12-24T07:51:30+05:00
[INFO] Final Memory: 15M/175M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.
4.3:test (default-test) on project wflow-directory: There are test failures.
[ERROR]
[ERROR] Please refer to F:\backup\jw-community-4.0-SNAPSHOT\wflow-directory\targ
et\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc
eption
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <goals> -rf :wflow-directory
F:\backup\jw-community-4.0-SNAPSHOT\wflow-app>clks
'clks' is not recognized as an internal or external command,
operable program or batch file.
Please refer to the following for further inspection.
Please try to post in appropriate forum category as well next time. Thanks.
