Hello All,
I have a question about select box with beanshell, below is the beanshell code of select box.
and it give me the error logs as below, but if I change the SQL clause in beanshell code from "SELECT id,name FROM app_userview" to "SELECT id,name FROM app_datalist", then it's functional,
Would you please help me to find out how to solve this issue?
Gene
beanshell code in select box
import org.joget.apps.form.service.*;
import java.sql.*;
import org.apache.commons.collections.SequencedHashMap;
import java.util.*;
import javax.sql.DataSource;
import org.joget.apps.app.model.AppDefinition;
public FormRowSet getData() {
Connection con=null;
PreparedStatement stmt = null;
ResultSet rs = null;
String sql = "";
FormRowSet f = new FormRowSet();
f.setMultiRow(true);
DataSource ds = (DataSource) AppUtil.getApplicationContext().getBean("setupDataSource");
con = ds.getConnection();
if(!con.isClosed()){
String sql = "SELECT id,name FROM app_userview";
stmt = con.prepareStatement(sql);
//stmt.setString(1,orgId);
rs = stmt.executeQuery();
FormRow r1 = new FormRow();
r1.put(FormUtil.PROPERTY_VALUE, "");
r1.put(FormUtil.PROPERTY_LABEL, "");
f.add(r1);
while (rs.next()) {
FormRow r2 = new FormRow();
//String id = rs.getString("id");
//String userviewName = rs.getString("name");
r2.put(FormUtil.PROPERTY_VALUE,rs.getString(1));
r2.put(FormUtil.PROPERTY_LABEL,rs.getString(2));
f.add(r2);
rs.close();
stmt.close();
con.close();
return f;
return getData();
ERROR 04 May 2015 00:01:28 org.joget.apps.form.lib.BeanShellFormBinder - Error executing script Sourced file: inline evaluation of: ``import org.joget.apps.form.model.*; import org.joget.apps.form.service.*; import . . . '' : Method Invocation r1.put : at Line: 40 : in file: inline evaluation of: ``import org.joget.apps.form.model.*; import org.joget.apps.form.service.*; import . . . '' : r1 .put ( FormUtil .PROPERTY_LABEL , appName ) Target exception: java.lang.NullPointerException at bsh.BSHMethodInvocation.eval(Unknown Source) at bsh.BSHPrimaryExpression.eval(Unknown Source) at bsh.BSHPrimaryExpression.eval(Unknown Source) at bsh.BSHBlock.evalBlock(Unknown Source) at bsh.BSHBlock.eval(Unknown Source) at bsh.BSHBlock.eval(Unknown Source) at bsh.BSHWhileStatement.eval(Unknown Source)
I'm getting different errors though. Please check.
You will need to include these in your coding.
allwatch
Hi Hugo,
I tried but failed again, would you please help me check it again.
Gene
allwatch
Hi Hugo,
Gene
