Hi, All:
I try to use datalist action to delete an application in userview, but the delete action won't remove the running process,
It will leave a application form without any information for the approver. it will confuse the approver,
How can I remove the running process once I delete the record from the datalist.
Thanks for your help
Jonathan Yang
Hi Jonathan,
Yes, you are right, you will only be able to delete the form data by doing so. The default Delete Datalist Action element behaves such as a general form data record remover and does not interfere with running process instances. You may need to deliberately call up a script to perform what you needed after deletion or to write a new Datalist Action Plugin.
