I´m trying to install and build source-code community edition, for develop, debug and test bean shell features im my pc, but the build failure in step "6. Skipping Build Test" to compile wflow-plugin-base, from "Build Source Code on Windows" manual (Build Source Code on Windows).
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.4.3:test (default-test) on project wflow-plugin-base: There are test failures.
Hi guys, are ok ?
See error below:
[INFO] Reactor Summary for wflow-app 7.0-SNAPSHOT:
[INFO]
[INFO] wflow-jdbc ......................................... SUCCESS [ 1.013 s]
[INFO] wflow-commons ...................................... SUCCESS [ 3.985 s]
[INFO] wflow-plugin-base .................................. FAILURE [ 5.195 s]
[INFO] wflow-plugin-archetype ............................. SKIPPED
[INFO] wflow-directory .................................... SKIPPED
[INFO] wflow-wfengine ..................................... SKIPPED
[INFO] wflow-core ......................................... SKIPPED
[INFO] wflow-consoleweb ................................... SKIPPED
[INFO] wflow-app .......................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10.468 s
[INFO] Finished at: 2022-09-29T12:36:55-03:00
My pom in wflow-commons directory below:
<build>
<plugins>
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<version>2.0.2</version>
<configuration>
<source>1.7</source>
<target>1.7</target>
</configuration>
</plugin>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-surefire-plugin</artifactId>
<version>2.4.3</version>
<configuration>
<skipTests>true</skipTests>
</configuration>
</plugin>
</plugins>
My pom in wflow-plugin-base directory below:
<plugin>
<configuration>
<skipTests>false</skipTests>
</configuration>
<executions>
<execution>
<id>integration-test</id>
<phase>integration-test</phase>
<goals>
<goal>test</goal>
</goals>
<configuration>
</configuration>
</execution>
</executions>
</plugin>
My pom in wflow-consoleweb directory below:
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>tomcat-maven-plugin</artifactId>
<version>1.0</version>
<configuration>
<port>8080</port>
<warSourceDirectory>${project.basedir}/target/jw</warSourceDirectory>
</configuration>
</plugin>
<plugin>
<artifactId>maven-war-plugin</artifactId>
<version>3.8.6</version>
<configuration>
<archive>
<manifestEntries>
<Dependencies>org.omg.api</Dependencies>
</manifestEntries>
</archive>
</configuration>
</plugin>
Can you find the exact error printout? Not enough info to go through.
Hi, the top of TEST execution error below:
T E S T S
Running org.joget.plugin.base.TestPluginManager
15:26:16.577 [main] ERROR org.springframework.test.context.TestContextManager - Caught exception while allowing TestExecutionListener [org.springframework.test.context.support.DependencyInjectionTestExecutionListener@3c818ac4] to prepare test instance [org.joget.plugin.base.TestPluginManager@5b69d40d]
java.lang.IllegalStateException: Failed to load ApplicationContext
