Populate spreadsheet from external database according to select box value
Hello,
I'm working with an external database.
I succeeded importing fields for a select box creating my own FormOptionsBinder plugin.
Now I want to populate a spreadsheet (possibly in an Ajax subform if it helps) according to the selected value.
I think I have to create my own load binder for this purpose, but I can't find which class I must inherit from or which interfaces I must implement. Do you have any examples of spreadsheet load binders?
Regards,
Raphaël
      Hello,
      I ended up using this, which works :
      public class IcaosListAjaxFormBinder extends FormBinder implements FormLoadBinder, FormLoadMultiRowElementBinder {
      public FormRowSet load(Element element, String primaryKey, FormData formData) {
      FormRowSet names = new FormRowSet();
       String processId = formData.getProcessId();
      if (primaryKey != null && processId!= null && !primaryKey.equals(processId)) {
                  //primaryKey != processId on AJAX loading because
      //primaryKey == manualName on AJAX loading
       RawPagesDao rawpagesdao = (RawPagesDao) AppContext.getInstance().getAppContext().getBean("rawPagesDao");
       Set<String> dataFromDB = rawpagesdao.getDatasFromManual(formData.getProcessId(), primaryKey);
       FormRow dataEntry = new FormRow();
       JSONStringer datasList = new JSONStringer();
      try {
      datasList.array();
      for (String dataName : dataFromDB) {
      datasList.object().key("dataName").value(dataName).key("selected").value(false).endObject();
      datasList.endArray();
       dataEntry.put("generationRequirementsNames", datasList.toString());
       } catch (JSONException ex) {
      LogUtil.error(getClassName(), ex, String.format("Encountered a JSON error: %s", ex.getMessage()));
      names.add(dataEntry);
      return names;
      //Add overriding stuff here
      Regards,
      Raphaël
      1. Anders
        That's great, thanks for sharing your solution!
      2. Raphaël
        You're welcome, but do you know how to format code in a pretty way?
