I've build 2 form, form B is designed to get field values from form A which ajax subform perfectly doing that with select box as trigger.
How if I want to get some field values from form A, not entire form A field values ?
Is there any other way to get submitted form value beside using ajax subform ?
Any advice very appreciated.
Have you tried using Form Hashvariables?
More info: Hash Variable
More specifically: Hash Variable#FormDataHashVariable
Hope that helps.
Cheers.
