spreadsheet values override
Good afternoon -
I am formatting a spreadsheet based on form (using ajax is does filter properly) so that if I pick an item, it also fills out the price for example. however it doesnt give me an option to change the value in the spreadsheet.
are there any tricks to set the price in a cell and provide the opportunity to update it?
      HI Anders - thank you for the reply. I am able to populate the spreadsheet from another form. however the spreadsheet doesn't allow me to change data populated.  the value populated is the only option...
        Hi, I am not sure I understand the question correctly. But perhaps this question Populate spreadsheet from external database according to select box value might help?
