Hi Rushikesh,
We have improved the documentation on this. Please have a look Process Status Menu to see if it helps.
Thanks!
Hi, request parameter is the parameter in the query string of the URL, for example if you have https://host/path?id=abc as your URL, then the value of #requestParam.id# will be "abc". Check out https://en.wikipedia.org/wiki/Query_string.
- Rushikesh Haral
from which url ?
I am trying to use process status in userview. I had followed documentation but can not figure out requestparam.id.
Can anyone tell what is requestparam.id and where it is located? I tried to take it from URL as per the documentation but not working?
