Load Form Binder Bean Shell binder to load value in the hidden field in the form
Hi, guys
I face some problem with my code, the staff category did not been fill by any value. Here are the code. Is there any problem?
import java.sql.Connection;
import java.sql.ResultSet;
import java.sql.SQLException;
import javax.sql.DataSource;
public FormRowSet load(Element element, String username, FormData formData) {
FormRowSet rows = new FormRowSet();
String category = #RequestParam.category#;
if(category.equals("Breakfast")){
if (username != null && !username.isEmpty()) {
Connection con = null;
try {
// retrieve connection from the default datasource
con = ds.getConnection();
String firstname = #currentUser.firstName#;
String badgeID;
// execute SQL query
if(!con.isClosed()) {
PreparedStatement stmt = con.prepareStatement("SELECT distinct employeeCode FROM dir_employment JOIN dir_user ON dir_user.id = dir_employment.userId WHERE dir_user.firstName = ? ");
stmt.setObject(1, firstname);
while (rs.next()) {
badgeID = rs.getString("employeeCode");
if (badgeID != null || !badgeID.isEmpty()){
PreparedStatement stmt1 = con.prepareStatement("SELECT * FROM app_fd_underweightstaff where c_badgeid = ? ");
stmt1.setObject(1, badgeID);
ResultSet rs1 = stmt1.executeQuery();
Boolean exist = false;
while (rs1.next()) {
exist = true;
FormRow r = new FormRow();
if(exist){
r.put("staffcategory", "RM 1");
}else {
r.put("staffcategory", "RM 2");
}else{
String id = FormUtil.getElementParameterName(element);
formData.addFormError(id, "the badgeID is empty");
} catch(Exception e) {
LogUtil.error("Sample app - Form 1", e, "Error loading user data in load binder");
} finally {
//always close the connection after used
try {
if(con != null) {
con.close();
} catch(SQLException e) {/* ignored */}
}else{
formData.addFormError(id, "no category");
return rows;
//call load method with injected variable
return load(element, primaryKey, formData);
      Hi, what is the error that is you are getting in the logs?
