Spreadsheet Formatting
This work
1.Formatting number
{{type:'numeric',numericFormat:{pattern:'0.000'}}}  (Works Okay)
2. Formatting Color works
renderer:function(instance, td, row, col, prop, value, cellProperties)
Handsontable.renderers.TextRenderer.apply(this, arguments);td.style.backgroundColor = '#FDE9D9';
}}   (Works Okay)
3. combining the above two does not work.
type:'numeric',numericFormat:{pattern:'0.00'},
Handsontable.renderers.TextRenderer.apply(this, arguments) ; td.style.backgroundColor = '#FDE9D9';
}}  Does not work. The spread sheet shows values 9.999999 when it should show 9.99
Example
type:'date',dateFormat:'MM/DD/YYYY' ,
Handsontable.renderers.TextRenderer.apply(this, arguments);td.style.backgroundColor = '#D8E4BC';
}} This works as well.
      Hi, this looks like something to do with the handsontable library. Personally I am not so familiar with it, perhaps you might want to try asking in the handsontable forum https://forum.handsontable.com/? There might be more relevant expertise there.
