Use this guide Import Menu to learn how to configure the Import Menu.
Add a delete button in Userview CRUD menu to clear your list, or use a database tool/manager (SQLYog for example, for MySQL DB) to truncate the DB table.
I have a problem loading a list from an Excel file (xlsx) using a Form and the import tool.
My Excel file is 736 lines long, but when loaded, the list contain a lot of blank lines and is about 32000 lines long ?
The stange thing is that I load another list from a 194 lines Excel file and I don't have the same problem.
What am I doing wrong ?
Is there a way to empty a list before reloading it ?
Thank you in advance,
Daniel
