Hi, once a task is completed it will no longer be available in the user's inbox. How is your process designed such that the task is still in the inbox?
Im trying to do something like this;
Few PIC can approve one request at the same time and they share the same inbox.
If approver 1 already checked and submitted, he cannot see the request in inbox again to avoid duplicate checking by same approver. Can give me some idea to do this?
I tried to use bean shell to control permission but i think the code is wrong as when i click the hyperlink to do checking it says "You have no permission".
Connection con = DatabaseConnection.getConnection(); final String queryCheck = "SELECT * FROM tablename WHERE approver_email = ? AND running_number = ?"; final PreparedStatement ps = conn.prepareStatement(queryCheck); ps.setString(1, approver_email); ps.setString(2, running_number); final ResultSet resultSet = ps.executeQuery(); if(resultSet.next()) { return false; } else { return true; }Thank you.
