As far as I know, "Field ID to control available options based on grouping" takes only 1 field therefore such feature you are trying to implement is not possible going by this feature. Dynamic Cascading Drop-Down List
I think you need to write your own custom code to achieve this.
I have a situation where a select box will use a JDBC Binder but the parameters ( 2 of them) come from the values of 2 other (preceding) select boxes on the form. I need help .. this is during the interactive, ie cascading drop-down lists - ie. this is before the form is saved
i tried to passing both values
Hi.
Thanks for the feedback, writing code means 2 things to me -
if its JDBC code - its still an issue to get 2 or more parameters to the code
if its java/beanshell code - iits still an issue to get 2 or more parameters to the code
if its a plugin - <>, this will take a complete setup/on-ramp of plugin development and testing .. i found the link below when searching but i think i need it to be 1. ajax cascade enabled and 2. supported
Filter SelectBox Options from Multiple Dependency Fields
